Cannot program cyclone IV with USB blaster
I have an Altera Cyclone IV EP4CE6E22C8N board which supports programming via JTAG USB, and so I have a USB blaster revision C and connected it to the JTAG port and installed the drivers for it through the Quartus Prime installer, but unfortunately every time I try to use the programmer with it plugged in, it hangs for a while then prints an error saying "Attempted to access JTAG server -- internal error code 82 occurred", running jtagconfig also says: "Error when scanning hardware - Server error", device manager also shows only USB blaster when as far as I know it should also be showing additional entries such as JTAG interface?
I tried different drivers but to the same effect, reinstalling quartus prime and all the drivers, no luck. I also tried running a windows 7 VM and installing quartus prime and the programmer drivers on there in case it was a compatibility issue, but the same happens, server says "server error" and the programmer hangs.
I looked in event viewer and the driver appears to be outputting errors:
I have also tried to install the drivers manually through the quartus prime 23 install directory.
I'm really not sure what to do anymore, hoping someone with more experience can help.
Thank you!
I am running Windows 11, X86 of course.
Hello, yes!
It turns out the USB blaster I ordered was defective, trying it with a replacement it worked no problem.
Additionally, for future reference, the defective one did not have a constant shining "ACT" light, and Windows event viewer reported status code 0 as problem starting.
Thanks!
- NurAiman_M_Intel
Please try to uninstall Quartus and USB blaster driver, and then reinstall while logged into an administrator account.
Aiman
- Jacek159
Hey Aiman,
Thank you for your reply.
I did try this, on a new machine even on an administrator account, and even ran the Quartus installer and programmer as administrator, but I'm getting the same behaviour.
Could this be an issue with the USB blaster perhaps? I'm getting the same thing even with the FPGA JTAG unplugged,
- NurAiman_M_Intel
-Do you have another USB Blaster that you can try with the same board and PC?
-or Can you try using the current USB Blaster on another PC and another working board?
Aiman
- Jacek159
I don't have another USB blaster on hand so I've gone ahead and ordered another one to see if this one is defective perhaps.
I also don't have another FPGA board on hand but if I run out of options I could get another prototype, I could also manually interface the JTAG, although I doubt the issue is with the FPGA board since the blaster has the same issues regardless of whether the board is connected or not.
From that and also trying another machine, I'm fairly sure either the blaster is incompatible or defective, or there's something wrong with the driver/JTAG server, although I'm also having issues getting it working with Linux as well.
I'll get back to you once I receive it!
- Jacek159
Hello, yes!
Thanks!
- NurAiman_M_Intel
- SandeshKumar
You can check conversation
https://community.altera.com/discussions/fpga-device/quartus-programmer-21-1-jtag-server-error-code-82-%E2%80%93-port-1309-cannot-be-bound/356252
- SandeshKumar
I am facing a very similar problem with my Cyclone IV FPGA board and would appreciate some guidance.
My hardware is:
- FPGA: Altera/Intel Cyclone IV E EP4CE6E22
- FPGA board: Cyclone IV development board
- Operating System: Windows 11 64-bit
- Quartus Prime / Quartus Programmer: 21.1
- Programmer: Altera USB-Blaster
The USB-Blaster is detected by Windows Device Manager. However, Quartus Programmer cannot detect the FPGA through JTAG.
When I run:
jtagconfig
I get:
Quartus Programmer also reports:
I checked the JTAG Server and found the following:
jtagserver --status
Server is running
Remote clients are disabled
However, when I run:
jtagserver.exe --foreground
I get:
Unable to bind changedetect socket: 10048
Can't bind to TCP port 1309 - exiting
I then checked port 1309 using:
netstat -ano | findstr 1309
and got:
TCP 0.0.0.0:1309 0.0.0.0:0 LISTENING 4928
UDP 127.0.0.1:1309 127.0.0.1:1309 4928
So port 1309 is currently being used by PID 4928.
I have already tried:
- Reinstalling the USB-Blaster driver
- Installing the driver manually from the Quartus driver directory
- Trying different USB ports
- Restarting the PC
- Disconnecting the FPGA and testing the USB-Blaster separately
- Reinstalling/restarting the JTAG Server
- Checking the JTAG Server status
- Checking TCP port 1309
- Running the commands as Administrator
The USB-Blaster is detected by Windows, but Quartus still cannot communicate with it through the JTAG Server.
I would like to know if anyone has experienced this issue with Cyclone IV EP4CE6E22 on Windows 11.
Could someone please advise me on:
1. What exactly could be using port 1309?
2. How can I safely identify and remove the process/service occupying port 1309?
3. Is there a known JTAG Server compatibility issue with Quartus Programmer 21.1 and Windows 11?
4. Should I use a different Quartus Programmer version?
5. Is there anything else I should check on the USB-Blaster/JTAG connection?
I would really appreciate any help or suggestions.
Thank you.
