glenenglish's avatar
glenenglish
1 hour ago
Help on understanding Agilex5 speed binning and static power
Agilex 5 parts have  high static power by industry  traditions, so using Agilex in our designs needs some attention.
Using the PTA  26.1.110: fixed junction temperature
Is there going to be facility in the PTA to vary the core power supply values over the min and max range ? via tcl ?
Will there be a model update soon? most of the values I get seem same for ES and production silicon in the PTA.
(static power , 50 deg C, typical )  power of 100 DSPs at 200 MHz, + LPDDR4(32 + usage defaults)
A5EE008BB23BE6X   : 551mW ,   + 200mW, +576 mW
A5EE008BB23BE6S   : 759mW, +200mW  , +576mW
A5EE008BB23BE5S   : 666mW, +216 mW, +592mW
A5EE008BB23BE4S   : 739mW   , +227mW, +604mW
sweet spot speed/static/cost appears to be -5
notes : Static power is  2x   Xilinx ZU2CG....
Turning on all those I/Os for the EMIF LPDDR4   hurts alot for Agilex5. ALthough the defaults for EMIF write/read and toggle rates  are high (50%) so, might be pessimistic.
But, the DSPs consume about half what XIlinx Ultrascale+ does....
FWIW Xilinx Ultrascale+ DSP consumption is 560mW (25x18)  for same task. So Agilex wins there .
(but Ultrascale+ can operate much faster -1 xilinx (slowest) = -2V Agilex (fast))  .
Agilex 5 static and I/O power is massively higher, but when it gets busy, Agilex 5 fabric functions are lower power cost than Ultrascale+. Agilex5 may not be the best choice for battery operated devices... Agilex 5 is best when it is busy and heavily utilized, only then it has power advantages over Ultrascale+
Glen
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
