sbj's avatar
sbj
2 months ago
Agilex 5 GTS Reference Clock Buffer Protection
While reviewing the Agilex 5 GTS documentation, I found that the Input Reference Clock Buffer Protection mechanism automatically disables the reference clock buffer when the input clock is not toggling, and that the documented recovery methods are either reconfiguration or a buffer turn-on request.
For an Agilex 5 design, I would like to clarify:
  1. Is there any supported method to keep the GTS reference clock buffer permanently enabled?
  2. Can the Input Reference Clock Buffer Protection mechanism be disabled?
  3. Is there any alternative to repeatedly issuing a Buffer Turn-on Request when the reference clock may stop and restart during normal operation?
  4. If not supported, is the documented re-enable procedure the only recommended approach?
  • Hi sbj ,
    I hope you’re doing well. I wanted to follow up and check if there are any remaining questions or concerns regarding this matter.
    Please let us know if anything still needs clarification — we’re happy to assist further.
    Thank you for your time, and we look forward to your feedback.
    Best Wishes
    BB
  • Hi sbj
    Please find the below response on the question you have:
    Best Wishes
    BB
