Almost right!
The fact that the verilog is output reg ack; states that the signal ack is an output from this module. In your VHDL you need to ensure that the signal ack is defined as an output port on your entity. entity test_e is port ( ... ack : out std_logic ... ); end entity test_e; also remember that in VHDL you will not be able to put an output signal on the Right hand side of an expression. i.e you may need an intermediate signal and assign that to your module output - Altera_Forum
another one verilog declaration:
reg [31:0] internal_regs[3:0] how the codes in vhdl looks like? - Altera_Forum
This is a 2 dimensional array i.e. an array of 16 * 32 bit values You will need to define a type like type regs_type is array (0 to 15) of std_logic_vector(31 downto 0) then a signal signal internal_regs : regs_type; elements are references as internal_regs(0) <= X"12345678"; or for bit access internal_regs(0, 1) <= '0'; etc Hope this helps - Altera_Forum
thx. really help me. i added to your reputation. Another question:
Verilog codes: reg [31:0] internal_regs[3:0]; input [31 downto 0] dati; always@(posedge clk) begin .. internal regs[addr[4:2]] <=dati; .. end I have write my vhdl code for the line 70 as: internal_reg(addr(4 downto 2)) <= dati; --line 70 but i got the following error: Error (10381): VHDL Type Mismatch error at wb_prom.vhd(70): indexed name returns a value whose type does not match "integer", the type of the target expression how to change the code in line 70?? - Altera_Forum
Is it because you wrote "internal_reg" instead of "internal_regs"?
nope..sorry..internal_regs what i wrote my vhdl programme..with 's'
It seems that you are trying to write three bytes
internal_reg(addr(4 downto 2)) into a 32-bit register, so you should adjust the indexes in order to write 4 bytes instead of 3. - Altera_Forum
i cannot do that because dati is 32 bits width. I have an idea which is, i must convert the addr(4 downto 0) to integer.in that means internal_regs(integer) which corresponds one of the array of 32 bits. but to convert this (4 downto 2) into integer is another problem. i have tried conv_integer(addr(4 downto 0)) but failed
Array indexes have to be an integer
so for internal_reg(addr(4 downto 2)) <= dati; --line 70 you need to cast addr(4 downto 2) into an integer something like include the library use ieee.std_logic_unsigned.all internal_reg(to_integer( unsigned(addr(4 downto 2)))) <= dat; you need to cast a std_logic_vector to an unsigned, then an unsigned to an integer. - Altera_Forum
I think it should be (3 downto 0) to be an integer
