17 years agosimple verilog to vhdl translation question
hello, in a verilog module i found a declaration, that is, output reg ack; in vhdl translation, i can simply write : signal ack; am i right??
17 years agothx. really help me. i added to your reputation. Another question:
Verilog codes: reg [31:0] internal_regs[3:0]; input [31 downto 0] dati; always@(posedge clk) begin .. internal regs[addr[4:2]] <=dati; .. end I have write my vhdl code for the line 70 as: internal_reg(addr(4 downto 2)) <= dati; --line 70 but i got the following error: Error (10381): VHDL Type Mismatch error at wb_prom.vhd(70): indexed name returns a value whose type does not match "integer", the type of the target expression how to change the code in line 70??
