17 years agosimple verilog to vhdl translation question
hello, in a verilog module i found a declaration, that is, output reg ack; in vhdl translation, i can simply write : signal ack; am i right??
17 years agoreg [31:0] internal_regs[3:0]
This is a 2 dimensional array i.e. an array of 16 * 32 bit values You will need to define a type like type regs_type is array (0 to 15) of std_logic_vector(31 downto 0) then a signal signal internal_regs : regs_type; elements are references as internal_regs(0) <= X"12345678"; or for bit access internal_regs(0, 1) <= '0'; etc Hope this helps
