17 years agoHelp me in translation of VHDL to verilog
Hello!
How can i convert a two-dimentional output & input port of vhdl into a verilog. vhdl: type VARIABLEARRAY is array (1 to NBRVARIBLE_CT+10 ) of SLV32; ---------------------------------------------------------------- one input port varaarayin is declared as a type of VARIABLEARRAY. & one output port vararrayout is also declared as a type of VARIABLEARRAY. ----------------------------------------------------------------- I need a equivalent code for this because verilog didnt support 2-D array as input or output port.am i correct? -------------------------------------------------------------------12 Replies
In case you don't really need a bidirectional wire but have declared this signal as inout because of the VHDL readback restrictions then you just can declare the signal as reg in Verilog.
There is an example that might help you here
http://www.altera.com/support/examples/verilog/ver_bidirec.html In fact http://www.altera.com/support/examples/verilog/verilog.html Has a lot of good examples of Verilog coding that might be of interest to you. Hope it is what you want - Altera_Forum
ya thats ture.
thanks for clearing my doubt. I am having one more doubt i have declared one port as inout. so in verilog ideally it should be wire. but I am assigning some value to same port inside the always block. so for that perpose.it should be a reg only. so it is showing the error msg:port mode is incompatible with declaration. so please suggest me some alternative for above problem Regards, Manoj - Altera_Forum
If the other modules in your system need to interface to your internal 2D array and are written in Verilog then yes they will also need to flatten the array to/from the ports as you have done.
All languages have restrictions and unlucky for you that you found one of the Verilog ones :confused: Hope this has helped - Altera_Forum
@vernmid,
Thanks for valuable reply. You are correct.but i am having restriction to use of verilog only. i did the same thing as you suggested,flatten the 2-D array in my module, but main problem is the dependency of my module on various module also, so should they people also have to modify their modules? Regards, Manoj - Altera_Forum
You are correct that Verilog does not support arrays in input and output ports.
You will need need to either define vectors as input and outputs and assign them to a 2D array inside your module i.e. flatten the 2D array to a vector for i/o to the module. or I believe System Verilog would do what you want - Altera_Forum
I need to have used the variables as both input & output port. some variable as input port other as a output port.. Regards, Manoj - Altera_Forum
--- Quote Start --- Hi, Dear GKP, exectly same thing as you wrote.but i think,we cant declare the port variable like that // reg [7:0] mem [15:0] // as 2-D array.in verilog. can you suggest me some alternative for that.. Regards, Manoj --- Quote End --- Now I'm a little bit confused. Are talking about input or output port of a module ? Kind regards GPK - Altera_Forum
Dear GKP, exectly same thing as you wrote.but i think,we cant declare the port variable like that // reg [7:0] mem [15:0] // as 2-D array.in verilog. can you suggest me some alternative for that.. Regards, Manoj - Altera_Forum
--- Quote Start --- @GKP, I am explaining with the help of example. e.g. variablearray is array (1 to nbrvarible_ct+10 ) of slv32; the equivalent memory space occupy by this 2-D array in terms of 1-D array is... var1[(NBRVARIBLE_CT+10)*32:0] ;//here var1 is the array of (NBRVARIBLE_CT+10) locations & the each location of this array is of 32 bit wide.. I hope this is the proper explaination for you. --- Quote End --- Hi, you would like to define a memory ? reg [7:0] mem [15:0] // defines a 16x8 memory , Data width 16 bit, Address width 8bit Kind regards GPK
