17 years agoHelp me in translation of VHDL to verilog
Hello! How can i convert a two-dimentional output & input port of vhdl into a verilog. vhdl: type VARIABLEARRAY is array (1 to NBRVARIBLE_CT+10 ) of SLV32; ----------------------------...
17 years agoya thats ture.
thanks for clearing my doubt. I am having one more doubt i have declared one port as inout. so in verilog ideally it should be wire. but I am assigning some value to same port inside the always block. so for that perpose.it should be a reg only. so it is showing the error msg:port mode is incompatible with declaration. so please suggest me some alternative for above problem Regards, Manoj
