About floating voltage of the Agilex 3 power on reset
I am Naken, thank you for your support.
I have created a board equipped with Agilex 3 and started debugging it recently.
When checking the power pins during power-up, it appears that a floating voltage from the VCC system (0.75V) is entering the power system that supplies HVIO (3.3V).
(I can send images individually if needed.)
As described in the documentation, it mentions that due to floating voltage, VCCIO_PIO can be affected by VCCPT.
3.3. Floating Voltage • Power Management User Guide Agilex™ 3 FPGAs and SoCs • Altera Documentation and Resources Center
Is it possible that the HVIO group experiences floating voltage due to the influence of the VCC system group?
Naken
- AqidAyman_Altera
Hello Naken,
Thank you for reaching out to us.
Yes, I do need the images if you can provide. Let me know if you need to share this in private.
Aqid
- Naken
Hello Aqid,
Thank you for your reply.
I would like to share you in private, how do I ?
Naken
- AqidAyman_Altera
Hi Naken,
I have reach out to you in private. Please check your inbox.
Aqid
- Naken
Hello Aqid
I sent the message to your box. Please check your inbox.
Naken
