17 years agoHelp me in translation of VHDL to verilog
Hello! How can i convert a two-dimentional output & input port of vhdl into a verilog. vhdl: type VARIABLEARRAY is array (1 to NBRVARIBLE_CT+10 ) of SLV32; ----------------------------...
17 years ago@vernmid,
Thanks for valuable reply. You are correct.but i am having restriction to use of verilog only. i did the same thing as you suggested,flatten the 2-D array in my module, but main problem is the dependency of my module on various module also, so should they people also have to modify their modules? Regards, Manoj
