17 years agoData corrupted, any problem with VHDL codes
HI everyone.
I just have a quick question to ask. When we use the LOOP in VHDL, is there any chances that the number of times the LOOP is repeated affects the data, say, in the following piece of code, the code "content(i) <= content(i+1)" is repeated 65 times (content is an array of 8bit number), and the data I get at the output of the Modules (dataout[7:0]) is corrupted at some points: -- ram.vhd library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity RAM is generic ( bits: integer := 8; words: integer:= 66); port (clk_in: in std_logic; clk_out: in std_logic; we: in std_logic; re: in std_logic; reset: in std_logic; datain: in std_logic_vector(bits - 1 downto 0); dataout: out std_logic_vector(bits - 1 downto 0) ); end RAM; architecture beh of RAM is signal readp: integer range 0 to words; type table is array (0 to words - 1) of std_logic_vector(bits-1 downto 0); signal content: table :=(others => "10000000"); begin process(reset,clk_in, we) begin if (reset = '1') then content <= (others => "10000000"); elsif (clk_in'event and clk_in = '1') then if (we = '1') then for i in 0 to words - 2 loop content(i) <= content(i+1); --***could it be this line? *** end loop; content(words - 1) <= datain; end if; end if; end process; process(clk_out, re) begin if (clk_out'event and clk_out = '1') then if(re = '1') then dataout <= content(readp); end if; end if; end process; process(clk_out, re, reset) begin if (reset = '1') then readp <= 0; elsif (clk_out'event and clk_out = '0') then if(re = '1') then readp <= readp + 1; if(readp = words - 1) then readp <= 0; end if; end if; end if; end process; end beh; Any suggestion would be greatlly appreciated. Cheers. J.
