Bhanu_LFT's avatar
Bhanu_LFT
7 months ago
Support Request to Debug Signal Tap Issue with SoC Based Design(GHRD) on Agilex-7 FPGA
Hi Altera Support Team,
Greetings from Logic Fruit Technologies.
This is Bhanu Pratap and I am working  on the project in which we are using Agilex-7 SOC FPGA.
Goal: Utilize Agiliex-HPS's capability on a Linux OS to control dynamic features of IP Cores at runtime.
Problem Statement: We are facing an issue detecting SignalTap with SoC-based designs for runtime debugging while it's enabled and added from the Quartus project to generate the programming file.
Brief Description:
  1. We are using Quartus 2025.1.1 and Altera's Agilex-7 Devkit(DKSIAAGI027FA: Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit -> 4x F-Tile, Rev C).
  2. We downloaded the base GHRD design from Altera's GitHub webpage for the corresponding Quartus version.
  3. We are following each step to test GHRD and build generation for the Linux OS.
  4. We are using HPS First booting mode, we generated the build without modification and tested it. It's working fine according to the GSRD user guide.
  5. We have added a custom AXI4 Slave based CSR module to the HSP Lightweight bus to test basic register read/write using Platform Designer.
  6. We regenerated the build and re-tested but we are not getting the expected results so we added SignalTap for debugging.
  7. Build is generated using the STP file, programmed, and the OS is booting but it's not detecting SignalTap.
This looks more like a process gap. We seek your support to fix this issue.
Note: If we use an FPGA design without HPS, we are able to add and detect SignalTap.
Seeking for urgent support.
Bhanu Pratap
  • Hello Bhanu Pratap,
    For the HPS design, the system uses a two-phase configuration process.
    When programming the initial binary, only the HPS component is configured. During the subsequent boot process, the FPGA core must be loaded separately. SignalTap can only detect signals after the FPGA core has been successfully loaded.
    I am not certain whether your current boot script handles this sequence correctly. As a simple validation, I recommend changing the design to use FPGA-first boot mode and recompile the project.
    To do this, please open Device Settings in Quartus and change the configuration order to After INIT_DONE.
    If this approach works, please let me know how you are currently booting the system in Linux, and I can guide you on the correct procedure to load the FPGA core.
    Shun Jing
    Details:
  • KianHinT_altera's avatar
    KianHinT_altera
    Hi Bhanu_LFT​
    May I know whether your issue already been addressed by my colleague? If yes, could you set that as a solution and we will transition this case to future community support only.
    Kian
    KianHinT_altera
    Dear Customer,
    As we do not hear back from your end and case have been idling awhile, we will step back and allow the community to assist with any future follow-up questions.
    Altera Technical Support
