zamroodh's avatar
zamroodh
7 months ago
Agilex 5/3 FreeRTOS SMP Support
Stable Version: v25.4
Quartus Version: 25.4
Supported devices: Agilex™ 3 and Agilex™ 5
Source : https://github.com/Ignitarium-Technology/freertos-socfpga
Branch/Tag: v25.4-SMP
Release Date: March 30, 2026
Hello Everyone,
FreeRTOS port for A55/A76 HPS now supports SMP. visit the GitHub page for instructions on how to get started.
Features and comments
FeaturesAgilex3Agilex5Agilex3 SMP
Agilex5 SMP
(A55 x 2 or A76 x 2)
Supported featuresLimitations/ Known issues
A55 bootYesYesYesYes
Single core boot, Dual core SMP
A76 bootNAYesNAYes
QSPI bootYesYesYesYes
SD bootYesYesYesYes
eMMC bootYesYesYesYes
NAND bootNoNoNoNo
Clk mngr driverYesYesYesYes
API to get clock speed of different blocks
Reset mngr driverYesYesYesYes
Peripheral reset assert/de-assert
DMA driverYesYesYesYes
Memory to memory transfer
Only support memory to memory
GPIO driverYesYesYesYes
Write, read and interrupt support
Timer driverYesYesYesYes
User defined and free running modes
UART driverYesYesYesYes
Full duplex Tx and Rx
DMA not supported (Planned for future release
I2C driverYesYesYesYes
Master mode write and read Standard and fast modes
I3C driverYesYesYesYes
Master mode write and read i3c and legacy i2c devices
IBI not supported (Planned for future release)
SPI driverYesYesYesYes
DMA is not supported
QSPI driverYesYesYesYes
QSPI flash read/write/erase
NAND driverNoNoNoNo
SDM mailbox driverYesYesYesYes
SDM commands with SIP_SVC
SMMU enable supportYesYesYesYes
Static identity mapping for cache coherency
SDMMC driverYesYesYesYes
standard and HS speeds SDMMC and eMMC devices
Fat FS support
Ethernet stackYesYesYesYes
TCP/IP, UDP, ICMP and DHCP
IPv4 and IPv6 support
USB 2.0 stackNTYesNTYes
USB mass storage class
 Tested with a custom board and SOF
USB 3.1 stackNTYesNTYes
USB mass storage operation
WDT diverYesYesYesYes
interrupt or reset on timer expiry
EDAC supportYesYesYesYes
Error injection and detection for EMAC, USB and QSPI blocks
OCRAM not supported
IOSSM driverYesYesYesYes
Bridge driverNTYesNTYes
Enable, Disable
Reboot mngrYesYesYesYes
Warm/Cold reboot
FPGA managerYesYesYesYes
FPGA configuration
Yes: Feature available and tested, No: Feature not available in SDK, NA : Not applicable , NT: Not tested
Note: If you find any issues, please raise an issue in the GitHub page.
For more support/assistance visit our website .
  • sonycman's avatar
    sonycman
    May i ask a question?
    Readme documentation Building boot images for SD card guides to make two files, sd_img and qspi_img.jic.
    And according to guide sd_img should contain .sof and bl2.hex files, which is wrong, if i'am understand correctly.
    Those two files must be in .jic, which is programmed to QSPI.
    SD card image should contain a fip image with user application and bl31 secure monitor.
    Am i wrong?
  • sonycman's avatar
    sonycman
    Hi Naji_Naufel,
    Yes, its the same page you are linked above, SD boot paragraph.
    As well as i understand, qspi_image.jic contains BL2 bootloader and .sof FPGA bitstream.
    The same is core.rbf.
    So this command:
    make_sdimage.sh -s 128 -o sd.img -p "a2:2:64:fip.bin" -p "c:1::fatfs/core.rbf"
    places on SD card the same files (in core.rbf) as in qspi image?
    As i understand, booting proceeds loading .sof and BL2 from QSPI first, then BL2 loads .fip from sd card fat partition.
    I'am interested for what the core.rbf (with doubled bl2 and .sof) was placed on sd card?
  • sonycman's avatar
    sonycman
    I thought i see now.
    core.rbf file was stripped of bootloader code before being written to sd card.
    And QSPI contains .sof data too to support both HPS-first and FPGA-first boot modes, am i right?
    In FPGA-first bitstream being loaded from QSPI, and in HPS-first bitstream being taken from sd card core.rbf?
    • kevinsuresh's avatar
      kevinsuresh
      Hi sonycman,
      The qspi_image.jic contains the properties of the .sof file we used to build the application. The sof file decides where the HPS or FPGA gets configured first. So it can't support both modes at once.
      In FPGA first boot, the bitstream gets configured at boot automatically. For the HPS first boot, the FPGA doesn't get configured until we use the fpga_manager driver to configure the FPGA. To make this easier, the sd_img contains the core.rbf bitstream file required for FPGA configuration so that the user doesn't need to build it and copy it.
      Hope this helps
      • sonycman's avatar
        sonycman
        Hi kevinsuresh,
        Thank you, now i get it. There is much to learn for me :)
        It seems bl31 secure monitor could not be excluded entirely? Its services heavily used?
  • sonycman's avatar
    sonycman
    Hello again!
    May i ask another question?
    In _mmu_configure function, setup_pagetable.c file:
    /*tcr_el1 = 0x18 | (0x1 << 8) | (0x1 << 10) | (0x3 << 12) | (0x1 << 23);*/
    tcr_el1 = 0x18 | ( 0x1 << 23 );
    Why is the caching of MMU page table walk is disabled (top line commented out)?
    The pages are lies in cacheable memory, so table walks should be also cacheable, isn't it?
    I working on my own little baremetal application, and very interested in MMU setup methods...
    Thanks in advance!
    Regards, Vlad.
      kevinsuresh
      Hi Vlad,
      You are right to point that out. The current implementation has a slight performance reduction compared to the line of code that is disabled. We have not enabled it as it isn't fully tested. From what I see, it's should be fine to enable it and run it. Once this is fully tested, it will be available in the next release.
      Kevin
