HPark14's avatar
HPark14
4 days ago
Inquiry on CVE-2026-98432 Patch Schedule, Custom Backport Support, and PSIRT Vulnerability Policy
Hello Altera Support Team,
One of our key customers is currently preparing compliance documentation (including EU Cyber Resilience Act / security audit requirements) and inquired about the status and handling policy for Linux kernel vulnerability CVE-2026-98432 (IPv4 TCP use-after-free, CVSS 9.8).
We verified that in the upstream Linux kernel, this vulnerability was resolved in the 6.18.56 stable release by replacing kfree() with kfree_rcu() in inet_sock_destruct() (net/ipv4/af_inet.c) and tcp_v4_reqsk_destructor() (net/ipv4/tcp_ipv4.c). However, on the current `socfpga-6.18.37-lts` branch in `github.com/altera-fpga/linux-socfpga` (used in GSRD 26.3), both functions still use kfree().
To provide an official response to our customer, please confirm the following three items:
  1. Patch Plan & Release Schedule for CVE-2026-98432
    - Is there a plan to include the fix for CVE-2026-98432 in `linux-socfpga` / GSRD?
    - If yes, in what form will it be delivered (e.g., rebasing to upstream 6.18.56 or later in the next GSRD release, or a patch update on top of 26.3), and what is the estimated release timeline?
  2. Support Scope for Customer-Applied Backport via Yocto Layer
    - Until an official Altera kernel update is available, our customer plans to backport the upstream 6.18.56 patch onto `socfpga-6.18.37-lts` via their custom Yocto layer.
    - Does Altera recommend this approach, and will applying this upstream network-stack patch impact Altera's official technical support scope for SoC hardware and Altera IP drivers?
  3. Altera Security Vulnerability (PSIRT) Management & Upstream Sync Policy
    - Where are official security advisories (PSIRT) for GSRD and `linux-socfpga` published? (Is it managed exclusively via the Altera Product Security Advisories portal, or is there a separate mailing list/feed for `linux-socfpga`?)
    - What is Altera's standard cadence and SLA/lead time for integrating upstream Linux LTS security patches into `linux-socfpga` and GSRD releases? (Our customer requires this policy description as official evidence for their vulnerability management framework.)
Thank you in advance for your prompt review and confirmation.
Hudson
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi
    Please give us sometime to work out the details and get back to you on this.
