rajas_patil's avatar
rajas_patil
13 hours ago
Repeated EDAC SEU UE Errors on Agilex 7 AGI027FB
Hello Team,
I am booting Linux on the Agilex 7 development board (AGI027FB) using the Yocto-based Poky Linux distribution.
During boot, the kernel continuously reports the following EDAC (Error Detection and Correction) messages related to the Altera ECC Manager and the cram-seu0 block.
The messages appear at regular intervals of approximately 4–5 seconds and continue even after Linux has completed booting and reached the login prompt.
Board: Agilex 7 Development Kit (AGI027FB)
Quartus Version: Quartus Prime Pro Edition 2025.3.1
Logs snippet :
[   12.161133] EDAC Altera: SEU UE: Count=0x8, SecAddr=0x30, ErrData=0x0
[   12.167617] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.187218] EDAC Altera: SEU UE: Count=0x7, SecAddr=0x30, ErrData=0x0
[   12.193645] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.213221] EDAC Altera: SEU UE: Count=0x6, SecAddr=0x30, ErrData=0x0
[   12.219650] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.239241] EDAC Altera: SEU UE: Count=0x5, SecAddr=0x30, ErrData=0x0
[   12.245677] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.265249] EDAC Altera: SEU UE: Count=0x4, SecAddr=0x30, ErrData=0x0
[   12.271689] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.291270] EDAC Altera: SEU UE: Count=0x3, SecAddr=0x30, ErrData=0x0
[   12.297696] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.317269] EDAC Altera: SEU UE: Count=0x2, SecAddr=0x30, ErrData=0x0
[   12.323698] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
[   12.343277] EDAC Altera: SEU UE: Count=0x1, SecAddr=0x30, ErrData=0x0
[   12.349704] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu'
We also tried by un-tick the "Enable error detection check" (screenshot attached). Still we get the same thing as above. Do we need any more config changes either in Quartus or anywhere during Yocto build ?
Need support for the same.
Let me know if any more information is required.
Thank You!
Rajas Patil
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
