hps boot
106 TopicsRepeated EDAC SEU UE Errors on Agilex 7 AGI027FB
Hello Team, I am booting Linux on the Agilex 7 development board (AGI027FB) using the Yocto-based Poky Linux distribution. During boot, the kernel continuously reports the following EDAC (Error Detection and Correction) messages related to the Altera ECC Manager and the cram-seu0 block. The messages appear at regular intervals of approximately 4–5 seconds and continue even after Linux has completed booting and reached the login prompt. Board: Agilex 7 Development Kit (AGI027FB) Quartus Version: Quartus Prime Pro Edition 2025.3.1 Logs snippet : [ 12.161133] EDAC Altera: SEU UE: Count=0x8, SecAddr=0x30, ErrData=0x0 [ 12.167617] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.187218] EDAC Altera: SEU UE: Count=0x7, SecAddr=0x30, ErrData=0x0 [ 12.193645] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.213221] EDAC Altera: SEU UE: Count=0x6, SecAddr=0x30, ErrData=0x0 [ 12.219650] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.239241] EDAC Altera: SEU UE: Count=0x5, SecAddr=0x30, ErrData=0x0 [ 12.245677] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.265249] EDAC Altera: SEU UE: Count=0x4, SecAddr=0x30, ErrData=0x0 [ 12.271689] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.291270] EDAC Altera: SEU UE: Count=0x3, SecAddr=0x30, ErrData=0x0 [ 12.297696] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.317269] EDAC Altera: SEU UE: Count=0x2, SecAddr=0x30, ErrData=0x0 [ 12.323698] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' [ 12.343277] EDAC Altera: SEU UE: Count=0x1, SecAddr=0x30, ErrData=0x0 [ 12.349704] EDAC DEVICE2: UE: Altera ECC Manager instance: cram-seu0 block: cram-seu0 count: 1 'cram-seu' We also tried by un-tick the "Enable error detection check" (screenshot attached). Still we get the same thing as above. Do we need any more config changes either in Quartus or anywhere during Yocto build ? Need support for the same. Let me know if any more information is required. Thank You! Best Regards, Rajas Patil273Views0likes6CommentsIntel Startix 10 UART not showing up
Purchased Intel Stratix 10 board and when we tried to power on and connect the mini-usb port on HPS IO48 daughtercard to laptop/Linux machine the port is not getting detected. tried with troubleshooting by changing the cable , restarting the board but no luck. Need input what can be done to fix it for detecting the UART port from daughter card or any other ways to access the console? like can we boot from the boards UART port?45Views0likes3CommentsRelease 26.3
Version: Release 26.3 PRO Quartus Build/TAG: QPDS26.3 B114/QPDS26.3_REL_BASELINE_PR Release Date: October 28, 2026 Device Affected: Agilex® 27 , Agilex® 3, Agilex® 5, Agilex® 7, N5X, Stratix® 10, Arria® 10 Release Type: Major release Binary Release Path: http://releases.rocketboards.org/2026.10/ Release Page: https://github.com/altera-fpga/gsrd-socfpga/releases/tag/QPDS26.3_REL_BASELINE_PR Major Features Released Simics Simulator support for Agilex® 27 device and System Example Design created. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-27/common/virtual-platforms/linux-gsrd/ug-linux-gsrd-agilex27-virtual-platforms/ System Example Design to support HPS AMP supporting configurations Linux + FreeRTOS, FreeRTOS+FreeRTOS for Agilex® 5. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/e-series/premium-065a/amp_bao/ug-amp-bao-agx5e-premium-065a/ Support of Ethernet in Nios V example for Agilex® 3 Atum A3 Nano dev kit using MSGDMA to connect with SDR SDRAM. Reference Design of a DisplayPort video output subsystem for use by the Application Processor for a Linux desktop display HMI use case for Agilex® 5. Improved BareMetal support raising the API abstraction level for Agilex® 5 and Agilex® 3. Support of USB3.1 for Agilex3 and Agilex5 in device mode. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/e-series/premium-065a/baremetal/ug-baremetal-agx5e-premium-065a/ Re-activated the Zephyr support including driver support of peripherals, examples and BSP generation for Agilex® 5 and Agilex® 3. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/e-series/premium-065b/gsrd-zephyr/ug-zgsrd-agx5e-premium-065b/ https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/common/virtual-platforms/zephyr-gsrd/ug-zephyr-gsrd-agilex5-virtual-platforms/ Nios V Interfacing with Multi-Rate Ethernet PHY IP. Support of Use Case: mSGDMA IP in FPGA Fabric Connected to F2S bridge, via AXI security bridge (to allow ACE-Lite signals to be adjusted), SGDMA CSR's connected to H2F. HPS FreeRTOS Multicore Support for Agilex® 5. Support of Visual Design Studio (VDS) in all the Agilex® 7 System Example Designs. System Example Design for the Agilex® 5 Terasic DE25-Standard Board. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/terasic/de25-standard/gsrd/ug-baseline-de25-standard/ Support of Ubuntu running on HPS in Agilex® 5. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/e-series/premium-065a/ubuntu/ug-ubuntu-agx5e-premium-065a/ Support of Ubuntu running on HPS in Agilex® 5. https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-5/e-series/premium-065a/docker/ug-docker-agx5e-premium-065a/ Integrate test-suit executable into Yocto recipe in so this get available as part of the Linux file system for Agilex® 5. System Example Design to demonstrate Time-Sensitive Networking (TSN) PHY configuration using RGMII from FPGA HVIO for the Agilex® 5 013B. https://altera-fpga.github.io/rel-26.1.1/embedded-designs/agilex-3/c-series/tsn/rgmii-hvio/ug-tsncfg2-agx3c-dk-rgmii-hvio/ Support of Baseline System Example Design in Agilex® 7 devices. Support of Agilex® 7 HPS GSRD User Guide for I-Series FPGA Development Kit (rev D) https://altera-fpga.github.io/rel-26.3/embedded-designs/agilex-7/i-series/soc/gsrd-revd/ug-gsrd-agx7i-revd-soc/ Cache Coherent Accelerator System Example Design for Agilex® 5.58Views0likes1CommentWhy Generic Component are included in my GHRD?
Hi, Altera I am a Dist. FAE in Uniquest Korea. When building the Agilex 5 GHRD on a Linux OS, as you can see, the IPs are recognized as generic components. It would be great if an upgrade could fix this, but all the connections disappear and the design gets completely messed up. How do AEs deal with this goddamn situation? If the GHRD acts like this, there is no point for customers to use it as a reference design. Does anyone know a solution? I've tried copying the folders and creating new components, but I'm still just getting a bunch of red errors. Please let me know a solution.Are there any issues with the portability of Quartus designs?Sorry for bad languages.Thanks. HudsonSolved96Views0likes5CommentsPower management Agiilex 3/5 - Powerdown then HPS restart ?
I read in the power management section of (841346) Section 9 "Only power-off operations are supported, and they are done one time as a static option through boot mode user configuration. After power is turned off, the power manager does not support powering back on the CPU cores or L3 cache blocks." As I understand it = for a(partial ) power down , or power up of the HPS, the system needs to set some memory locations and then trigger a HPS restart and ther SDM has control then passes it to the FSBL. , then the FSBL can look at these locations and see what power mode it needs to come up or down as the system requires...... IE to change the power settings, there needs to be an HPS restart , or complete device configuration reload ? Perhaps put another way : In HPS boot-first mode : When a power CHANGE is required in the HPS domain, can the fabric stay running (assuming that there are no outstanding HPS<> fabric DMA requests or transactions pending across the fabric<>HPS bridge ) ? regards, glen.Solved385Views0likes9CommentsNAND flash issue with dual-core ARM® Cortex®-A9
The 5CSEBA2U19I7SN SoC HPS NAND pins are connected to a 4Gb NAND flash memory chip (S34ML04G200TFI003). In this design, the active-low Write Protect pin (#WP) is connected to both a 10kΩ pull-up resistor (to 3.3V) and a 10kΩ pull-down resistor (to Ground). During booting or flashing, a few NAND flash chips do not work properly, and a few nand flashes have been permanently damaged. Is connecting the #WP pin to both a pull-up and a pull-down resistor a correct hardware approach for cyclone SOC HPS NAND configuration? Best Regards, Keshav351Views0likes5CommentsStratix 10 Linux SD card booting
Hi Altera Community, I tried multiple attempts to boot the SD card from Rocketboard.org. https://releases.rocketboards.org/ I downloaded and booted the SD card with the .wic image file. It only has the .itb file by default in the boot partition. Whenever I try to boot, it asks for the U-Boot.img file. And also it says "failed to load "socfpga_stratix10_socdk.dtb" even if the file is there. And then I compiled my simple HPS design and can easily program the FPGA from the Quartus Programmer (rbf and sof file), but whenever I try to overlay it, like say: echo overlay.dtb > /sys/kernel?config?device-tree/overlays/0/path It says "FPGA manager error, timeout," and so on. Does any community member have notes or steps that you made to boot the SD card of the Stratix 10 FPGA? I am following this link: https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderStratix10324Views0likes12Comments25.3 PRO Release
Version: Release 25.3 PRO Quartus Build/TAG: B109/QPDS25.3_REL_GSRD_PR Release Date: October 10, 2025 Device Affected: Agilex™ 3, Agilex™ 5, Agilex™ 7, Startix® 10, Arria® 10 Release Type: Major release/Binary release Binary Release Path: http://releases.rocketboards.org/2025.10/ Major Features Released Support of GHRD 2.0 in Agilex™ 5 which includes foundational boot to Linux, ability to create compatible phase 2 bitstreams, parameterized HPS for maximum performance and best practices. Support of GSRD 2.0 Yocto layers for the Agilex 5 E-Series Premium DevKit with OOBE daughtercard for the GHRD 2.0 baseline design. Agilex 5 GSRD Development User Experience Improvement through KAS using a graphical/text interface to configure a limited number of high-level options on top of simplified Yocto recipes. - GSRD 2.0 with Kas Build System Support for running Agilex 5 Simics Simulation under the GSRD 2.0 framework. Booting from SD Card and QSPI is supported. - Exercising Simics Simulation from GSRD 2.0 Support GHRD and GSRD for Agilex™ M-Series PRQ HBM2e for DK-Sl-AGM039EA development kit. The GSRD is capable of booting to Linux. - Build the GSRD for DK-DEV-AGM039EA Hypervisor Multi-OS Support Example, demonstrating Linux and Zephyr running side-by-side in the HPS cluster. - HPS Xen Hypervisor GSRD System Example Design: Agilex™ 3 FPGA and SoC C-Series Development Kit Support for monitoring of SEU errors from the SDM in the HPS in Agilex™ 7. Add capability to measure the latency of Linux SMC calls. Support Nios V Lockstep application with a fail-safe mechanism742Views3likes12CommentsAgilex 5/3 FreeRTOS SDK Release
Stable Version: v26.1.1 Quartus Version: 26.1.1 Supported devices: Agilex™ 3 and Agilex™ 5 Source: https://github.com/Ignitarium-Technology/freertos-socfpga Branch/Tag: v26.1.1 Release Date: October 9, 2026 Hello Everyone, A new version of the FreeRTOS SDK for Agilex 5/3 is now available. This release contains some fixes, along with UHS-1(SDR12/25/50) support for SD/eMMC. Visit the GitHub repository for instructions on how to get started. Features and Comments Feature Agilex3 Agilex5 Agilex3 SMP Agilex5 SMP Supported Features Limitations / Known Issues A55 boot Yes Yes Yes Yes Single-core boot, Dual-core SMP, Quad-core SMP (Agilex 5) A76 boot NA Yes NA Yes Single-core boot, Dual-core SMP, Quad-core SMP QSPI boot Yes Yes Yes Yes eMMC boot NT Yes NT Yes SD boot NT Yes NT Yes NAND boot No No No No Clock Manager Yes Yes Yes Yes API to get clock speed of different blocks Reset Manager Yes Yes Yes Yes Peripheral reset assert/de-assert DMA driver Yes Yes Yes Yes Memory-to-Memory, Memory-to-Peripheral and Peripheral-to-Memory GPIO driver Yes Yes Yes Yes Write, read and interrupt support Timer driver Yes Yes Yes Yes User-defined and free-running modes UART driver Yes Yes Yes Yes Full-duplex TX and RX I2C driver NT Yes NT Yes Master/Slave mode, standard and fast modes QSPI driver Yes Yes Yes Yes QSPI flash read/write/erase I3C driver NT Yes NT Yes Master mode, I3C and legacy I2C devices SPI driver NT Yes NT Yes Master/Slave mode write and read NAND driver No No No No SDM Mailbox driver Yes Yes Yes Yes SDM commands with SIP_SVC SMMU support Yes Yes Yes Yes Static identity mapping for cache coherency SDMMC driver Yes Yes Yes Yes Standard and HS HS, and UHS-I (SDR12/25/50) speeds, SDMMC and eMMC devices, FATFS support Ethernet stack Yes Yes Yes Yes TCP/IP, UDP, ICMP, DHCP, IPv4 and IPv6 USB 2.0 stack NT Yes NT Yes USB mass storage class Tested with a custom board and SOF USB 3.1 stack Yes Yes Yes Yes USB mass storage operation WDT driver Yes Yes Yes Yes Interrupt or reset on timer expiry EDAC support Yes Yes Yes Yes Error injection and detection for EMAC, USB and QSPI blocks OCRAM not supported IOSSM driver Yes Yes Yes Yes Error injection and detection Bridge driver Yes Yes Yes Yes Enable/Disable bridges Reboot Manager Yes Yes Yes Yes Warm/Cold reboot FPGA Manager Yes Yes Yes Yes FPGA configuration Legend: Yes: Feature available and tested No: Feature not available in SDK NA: Not applicable NT: Not tested Note: If you find any issues, please raise an issue on the GitHub repository.103Views2likes1CommentIntroducing the Altera Community AI Responder — Beta
Altera is introducing the AI Responder, an assistant built into the Altera Community to help provide faster, context-aware guidance for Altera product questions. It uses relevant public Altera documentation and Knowledge Database content, with coverage continuing to expand. The AI Responder may provide source references and can hand off complex or out-of-scope questions to an Altera subject-matter expert. As a beta feature, responses may contain errors or omissions, so please review the sources and verify technical guidance against official Altera documentation before implementation. If the response does not fully address your question, add more context and tag ai_responder to continue the discussion. We welcome your feedback as we improve the Community experience.52Views0likes0Comments
