zamroodh's avatar
zamroodh
9 months ago
Agilex 5/3 FreeRTOS SDK
Stable Version: v25.4
Quartus Version: 25.3
Supported devices: Agilex™ 3 and Agilex™ 5
Source : https://github.com/Ignitarium-Technology/freertos-socfpga
Branch/Tag: v25.4
Release Date: January 16, 2026
Hello Everyone,
FreeRTOS port for A55/A76 HPS in Agilex 5/3 devices are now available for public. visit the GitHub page for instructions on how to get started.
Features and comments
Yes: Feature available and tested, No: Feature not available in SDK, NA : Not applicable , NT: Not tested
FeatureAgilex3Agilex5Supported featuresLimitations/ Known issues
A55 bootYesYesSingle core bootSMP not supported
A76 bootNAYesSingle core bootSMP not supported
QSPI bootYesYes
SD bootYesYes
eMMC bootYesYes
NAND bootNoNo
Clk mngr driverYesYesAPI to get clock speed of different blocks 
Reset mngr driverYesYesPeripheral reset assert/de-assert
DMA driverYesYesMemory to memory transferOnly support memory to memory
GPIO driverYesYesWrite, read and interrupt support
Timer driveryesyesUser defined and free running modes
UART driveryesyesFull duplex Tx and RxDMA not supported
I2C driverYesYesMaster mode write and read
Standard and fast modes
DMA not supported
I3C driverYesYesMaster mode write and read
i3c and legacy i2c devices
IBI not supported
SPI driverYesYesMaster mode write and readDMA is not supported
QSPI driverYesYesQSPI flash read/write/erase
NAND driverNoNo
SDM mailbox driverYesYesSDM commands with SIP_SVC
SMMU enable supportYesYesStatic identity mapping for cache coherency
SDMMC driverYesYesstandard and HS speeds
SDMMC and eMMC devices
Fat FS support
Ethernet stackYesYesTCP/IP, UDP, ICMP and DHCP
IPv4 and IPv6 support
100mbps and 1gbps operation
USB 2.0 stackNTYesUSB mass storage classTested with a custom board and SOF
USB 3.1 stackNTyesUSB mass storage operation
WDT driverYesYesinterrupt or reset on timer expiry
EDAC supportYesYesError injection and detection for EMAC, USB and QSPI blocksOCRAM not supported
IOSSM driverYesYesError injection and detection
Bridge driverNTYesEnable, Disable
Reboot mngrYesYesWarm/Cold reboot
FPGA managerYesYesFPGA configuration
Note: If you find any issues, please raise an issue in the GitHub page.
For more support/assistance visit our website .
  • jhonkanen's avatar
    jhonkanen
    Would it be possible to get example .pfg files for the cmake configuration
    cmake -B <build-dir> . -DCMAKE_BUILD_TYPE=Release -DSOC=AGILEX5 -DCORE=A55 -DSOF_PATH=<path to .sof file> -DPFG_SDMMC=<.pfg for sd/mmc> -DPFG_QSPI=<.pfg for qspi>
    • zamroodh's avatar
      zamroodh
      Hi jhonkanen​ ,
      I am attaching the pfg files for qspi and sd/mmc here.
      You may have to change the bitstream file name in the attached files, see the tag "<bitstreams>"
      <bitstreams>
          <bitstream id="Bitstream_1">
              <path hps_path="./bl2.hex">./ghrd_a5ed065bb32ae6sr0.sof</path>
          </bitstream>
      </bitstreams>
      Here the "ghrd_a5ed065bb32ae6sr0.sof" is the bitstream file name. use the same name as what we pass to the SOF_PATH macro.
      Note: if you are only building for either one, no need to provide the other.
