Agilex 5/3 FreeRTOS SMP Support
I thought i see now.
core.rbf file was stripped of bootloader code before being written to sd card.
And QSPI contains .sof data too to support both HPS-first and FPGA-first boot modes, am i right?
In FPGA-first bitstream being loaded from QSPI, and in HPS-first bitstream being taken from sd card core.rbf?
- kevinsuresh3 months ago
Hi sonycman,
The qspi_image.jic contains the properties of the .sof file we used to build the application. The sof file decides where the HPS or FPGA gets configured first. So it can't support both modes at once.
In FPGA first boot, the bitstream gets configured at boot automatically. For the HPS first boot, the FPGA doesn't get configured until we use the fpga_manager driver to configure the FPGA. To make this easier, the sd_img contains the core.rbf bitstream file required for FPGA configuration so that the user doesn't need to build it and copy it.
Hope this helps- sonycman3 months ago
Hi kevinsuresh,
Thank you, now i get it. There is much to learn for me :)
It seems bl31 secure monitor could not be excluded entirely? Its services heavily used?
Hi sonycman,
Glad I could help earlier.The secure monitor is used by the FPGA configuration module and the SDM mailbox module. The Remote System Update(RSU) library, FPGA cryptographic services library and the SEU module rely on the mailbox which in turn invoke the BL31 services through the Secure Monitor Call.
The FPGA related modules like the FPGA manager and bridge modules directly use the Secure Monitor Call for performing FPGA related functions. Some modules like USB3.1 require the FPGA to be configured for it to work successfully.
If the sof file can be a FPGA first boot, and the SDM mailbox dependant modules are not required, we can avoid using SMC calls.
