I've written a SDC file, I've compiled the design and it doesn't meet the timing constraints. I set the input and the output delays to zero. Have I written well the file?
# Created Clocks
create_clock -name clk -period 5 [get_ports clk]
create_clock -name clk2 -period 3.5 [get_ports clk2]
derive_clock_uncertainty
# Created Generated Clocks
derive_pll_clocks
# Set Clock Groups
set_clock_groups -asynchronous -group {clk} -group {clk2}
# Set False Paths
set_false_path -from [get_ports rst]
# Input Delays
set_input_delay -clock clk -max 0.0 [get_ports data_in[*]]
set_input_delay -clock clk -min 0.0 [get_ports data_in[*]]
set_input_delay -clock clk -max 0.0 [get_ports full_in]
set_input_delay -clock clk -min 0.0 [get_ports full_in]
set_input_delay -clock clk -max 0.0 [get_ports empty_in]
set_input_delay -clock clk -min 0.0 [get_ports empty_in]
# Output Delays
set_output_delay -clock clk -max 0.0 [get_ports wr[0]]
set_output_delay -clock clk -min 0.0 [get_ports wr[0]]
set_output_delay -clock clk2 -max 0.0 [get_ports wr[1]]
set_output_delay -clock clk2 -min 0.0 [get_ports wr[1]]
set_output_delay -clock clk2 -max 0.0 [get_ports rd[0]]
set_output_delay -clock clk2 -min 0.0 [get_ports rd[0]]
set_output_delay -clock clk -max 0.0 [get_ports rd[1]]
set_output_delay -clock clk -min 0.0 [get_ports rd[1]]
set_output_delay -clock clk -max 0.0 [get_ports full[0]]
set_output_delay -clock clk -min 0.0 [get_ports full[0]]
set_output_delay -clock clk2 -max 0.0 [get_ports full[1]]
set_output_delay -clock clk2 -min 0.0 [get_ports full[1]]
set_output_delay -clock clk2 -max 0.0 [get_ports empty[0]]
set_output_delay -clock clk2 -min 0.0 [get_ports empty[0]]
set_output_delay -clock clk -max 0.0 [get_ports empty[1]]
set_output_delay -clock clk -min 0.0 [get_ports empty[1]]
set_output_delay -clock clk2 -max 0.0 [get_ports data_mid[*]]
set_output_delay -clock clk2 -min 0.0 [get_ports data_mid[*]]
set_output_delay -clock clk -max 0.0 [get_ports data_out[*]]
set_output_delay -clock clk -min 0.0 [get_ports data_out[*]]
