14 years agoI'm using I/O files to test my design.First of all, Output Data aren't the same than Input Data. When I check the internal signals I see some control signals work wrong. Write and Read signals assert before Full and Empty ones (you can see it in the attached figure).
How are set_input_delay and set_output_delay used? What do you mean with set_clock_groups?
