14 years agoI got setup errors in both clocks, but when I've removed the set_output_delay commands they have disappeared. Why does it happen?
I have got this frequencies: 224.52 MHz (CLK) and 378.36 MHz (CLK2). They seem too low for a design made from two FIFOs. What is the maximum frequency for the DCFIFO? I generate the clocks using a testbench, have I to treat them as virtual clocks when I use the set_input_delay and set_output_delay commands?
