14 years agoI've written a SDC file, I've compiled the design and it doesn't meet the timing constraints. I set the input and the output delays to zero. Have I written well the file?
# ******************************************************* # Created Clocks # ******************************************************* create_clock -name clk -period 5 [get_ports clk] create_clock -name clk2 -period 3.5 [get_ports clk2] derive_clock_uncertainty # ******************************************************* # Created Generated Clocks # ******************************************************* derive_pll_clocks # ******************************************************* # Set Clock Groups # ******************************************************* set_clock_groups -asynchronous -group {clk} -group {clk2} # ******************************************************* # Set False Paths # ******************************************************* set_false_path -from [get_ports rst] # ******************************************************* # Input Delays # ******************************************************* set_input_delay -clock clk -max 0.0 [get_ports data_in[*]] set_input_delay -clock clk -min 0.0 [get_ports data_in[*]] set_input_delay -clock clk -max 0.0 [get_ports full_in] set_input_delay -clock clk -min 0.0 [get_ports full_in] set_input_delay -clock clk -max 0.0 [get_ports empty_in] set_input_delay -clock clk -min 0.0 [get_ports empty_in] # ******************************************************* # Output Delays # ******************************************************* set_output_delay -clock clk -max 0.0 [get_ports wr[0]] set_output_delay -clock clk -min 0.0 [get_ports wr[0]] set_output_delay -clock clk2 -max 0.0 [get_ports wr[1]] set_output_delay -clock clk2 -min 0.0 [get_ports wr[1]] set_output_delay -clock clk2 -max 0.0 [get_ports rd[0]] set_output_delay -clock clk2 -min 0.0 [get_ports rd[0]] set_output_delay -clock clk -max 0.0 [get_ports rd[1]] set_output_delay -clock clk -min 0.0 [get_ports rd[1]] set_output_delay -clock clk -max 0.0 [get_ports full[0]] set_output_delay -clock clk -min 0.0 [get_ports full[0]] set_output_delay -clock clk2 -max 0.0 [get_ports full[1]] set_output_delay -clock clk2 -min 0.0 [get_ports full[1]] set_output_delay -clock clk2 -max 0.0 [get_ports empty[0]] set_output_delay -clock clk2 -min 0.0 [get_ports empty[0]] set_output_delay -clock clk -max 0.0 [get_ports empty[1]] set_output_delay -clock clk -min 0.0 [get_ports empty[1]] set_output_delay -clock clk2 -max 0.0 [get_ports data_mid[*]] set_output_delay -clock clk2 -min 0.0 [get_ports data_mid[*]] set_output_delay -clock clk -max 0.0 [get_ports data_out[*]] set_output_delay -clock clk -min 0.0 [get_ports data_out[*]]
