14 years agoLooks quite OK to me.
You could do without the derive_pll_clocks, I believe you do not have a PLL in your design? You can group pins together, so you have less typing to do: { wr[0] rd[0] full[0] ... } and the [get_ports ... ] is not necessary. I usually set some small values for the input_delays, say -min 1.000 ns and -max 2.00 ns. If it is a submodule I'm testing I don't care about the output delays and set them all as false-paths What timing errors do you get?
