17 years agoIntrroducing delay at pin level
Hello All,
I am new to the Quartus tool, I just need your help to solve my doubts. I wanted to that "How to introduce output delay at pin level" Example: I have two input signals inp1, inp2 and two output signal op1 , op2 op1 <= not inp1; op2 <= not inp2; So if you see both outputs behaves same way., because the are implemented using not gate.. Now I need let say 10 ns more delay at op2 compare to op1 on the real hard ware.. So achieve this what kind of constraints I have to give. Thanks in advance Pavan M
