9 years ago
VIP Clocked Video Out Problem
I am having some problems with the VIP CVO IP. My QSYS core frequency is 100Mhz
But my CVO IP output must run at a different frequency. Initially I used 44.8Mhz
And it seemed to work ok. However, when I doubled the CVO clock in to 89.6
It stopped working – the LPDDR2 would not calibrate, etc. etc. Again, I’m applying
An external clock to the CVO (ITC) expecting it to sync between the internal 100Mhz
And external 89.6Mhz. I did not configure for a control port and simply relying on
The width/height, etc. setting which are not standard. Does it mean that the system
Can’t keep up with to 89.6? should I increase it to 120Mhz.
S.
