10 years agoVIP Clocked Video Out Problem
I am having some problems with the VIP CVO IP. My QSYS core frequency is 100Mhz But my CVO IP output must run at a different frequency. Initially I used 44.8Mhz And it seemed to work ok. H...
10 years agoShvitzer, AFAIK all VIP cores (not only CPS) require the license. Maybe CVO is the only exception. It is not clear why you need the Sequencer. Usually, it is used to combine two avalon-st streams into one or reorganize the sequence of the colour planes. You have only one stream...so not the first case. and you get your image from the Frame reader which allows you to specify the color sequence you need on the output.
The SD card controller requires the license too afaik....
