10 years agoVIP Clocked Video Out Problem
I am having some problems with the VIP CVO IP. My QSYS core frequency is 100Mhz But my CVO IP output must run at a different frequency. Initially I used 44.8Mhz And it seemed to work ok. H...
10 years agoYou may write your own sequencer to get rid of the one with license-fee, should not be that hard to write.
To give you a hint regarding the loading an image to the ddr, I need to understand your whole system-design first. -Which Chip do you use? An SoC with HPS, do you have a NIOS in your design? -Which width and height does the image has? -Do you just want to show an image, or several changing images, or a live-stream of a video source?
