10 years agoVIP Clocked Video Out Problem
I am having some problems with the VIP CVO IP. My QSYS core frequency is 100Mhz But my CVO IP output must run at a different frequency. Initially I used 44.8Mhz And it seemed to work ok. H...
10 years agoThanks uilka_b for replying. Yes I agree with you, I did not see the need for the CPS but when I remove it and go directly from the Frame Reader to the CVO it does not work. QSYS is happy
but it does not work. From what I can see, the CPS receives 4 bytes of which only 3 are needed (23:0 = RGB) and the 4th one (31:24) is discarded. I would love to get rid of it, what am I missing? Again, if I go directly from the Frame Reader to the CVO 3 color planes all the way things don't work, I don't get any license warning and no "time limited" .sof. But it does not work. Can someone explain this? The SD card controller from TERASIC simply uses 3 PIOs and some SW - don't need Altera's IP. Thanks, Guys
