10 years agoVIP Clocked Video Out Problem
I am having some problems with the VIP CVO IP. My QSYS core frequency is 100Mhz But my CVO IP output must run at a different frequency. Initially I used 44.8Mhz And it seemed to work ok. H...
10 years agoThanks Taz1984, I got it all working ! Instead of using the external clock I simply ran the ITC/CVO on the same streaming clock which I increased to match
to the external clock freq. I still have in the design the "Sequencer IP" which requires a license... it does not do very much other than discard the upper byte of the 32bit coming in from the Frame-Reader and going to the CVO. Can I do away with not using it? This is preventing me from putting the design into FLASH. My next task is loading an image into LPDDR but FAST. I am now using an external bridge (the Master on the Avalon-MM bus) to an SPI interface. It takes 20min to load into LPDDR... Any suggestions?
