Adithiya_R's avatar
Adithiya_R
1 year ago
Intel P-tile HIP clock not visible during timing analysis "all clock report"
Hi Everyone,
We are trying to run ptile pcie in end_point mode + user_logic, but during timing analysis "coreclkout_hip" the one generated by HIP ( hard pcie_ip core) and fed to user_logic , is not visible in the "all clocks report"
what would be the procedure to enable this?
In Gen 3 1x8 256 bit with 250 Mhz mode, Quartus is not able to automatically detect this "coreclkout_hip" and do the timing analysis of user_logic that's synchronous with respect to this clock
  • ShengN_altera's avatar
    ShengN_altera
    May i know you generate the design example with pio?
    Sheng
  • Adithiya_R's avatar
    Adithiya_R
    Hi Sheng
    • We generate the intel Ptile ip with our custom logic instead of PIO, and these are the following ports, which are given below
      rx/tx_pma_parllel_clk, ref_clk these are the only list getting visible, coreclkout_hip which is supposed to be 350 Mhz (gen4) or 250 Mhz(gen3) is not in the list
    • Requirement : To perform timing analysis with respect to coreclkouthip or the corresponding port in custom logic (user_clk)
    ShengN_altera
    Please make sure the output clock coreclkout_hip being used internally like feeding to other logic. Make sure there's fanout or usage internally. May I know possible provide the design for taking a look?
    Sheng
    Adithiya_R
    It is directly connected to user_app, user_clk port. But not identified as clock by Quartus.
    ShengN_altera
    Have you properly output the user logic? I'm adfraid it's being optimized away.
    Could you set Netlist Optimization Never Allowed to that user logic module?
    Sheng
    Adithiya_R
    Hi
    PLD_CLOCK_FREQ will eventually reflect as coreclkout_hip, is it ?
    if this is the setting , then user_logic ( bar_access fails ) ---- So suspecting this freq_change is causing some issues , for which we need timing_analysis wrt coreclkout_hip or user_clk
    And sof is working perfect for Gen3 and not working for gen4 where PLD_CLK_FREQ is the only change. why is that ?
  • Hi,
    I'm helping the PCIe part.
    --Yes
    --Probably the user logic part is not able to run correctly at 350MHz.
    Rong
    Adithiya_R
    Yes, our user logic is unstable at 350 MHz.
    To figure this out we need to enable the Timing analysis with respect to Coreclkout_hip
    That clock is not seen in the timing analysis. How to enable that?
  • Testing a PCIe Gen4 1x8 350MHz PIO design in Q25.1 Pro, the coreclkout_hip can be seen at the pio side as below screenshot. You may find similar clock input for your user logic.
    Another two 350MHz clocks from dut|dut|inst|Inst|maib_and_tile are from a pcie wrapper file already constrained in pcie sdc files.
    Rong
