dc3's avatar
dc3
7 months ago
Can't generate F-Tile Ethernet Hard IP Design Example
When I try to generate an example design for the F-Tile Ethernet Hard IP or even the F-Tile Low Latency 100G Ethernet IP, the generating step gets stuck in a loop and will stay that way until I manually stop it in Task Manager. Has anyone else encountered this issue?
  • Hello,
    May I know which Quartus version you're working with? Do the issue still persist?
    Pavee
    • dc3's avatar
      dc3
      I upgraded to 25.3.1 and now I get this error.
      • paveetirrasrie_Altera's avatar
        Form the screenshot you've provided, the design has error. You won't be able to generate the design with error.
        Please select the valid Device Initialization Clock and continue with generation.
        Pavee
  • dc3's avatar
    dc3
    After retrying again, the generation step loops like before. Is there any way I could get a pre-made example design to download instead?
