Serge93's avatar
Serge93
3 months ago
F-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
Hello Support,
I am using the Agilex 7F Dev Kit with F-Tile configured in Root Port Gen3x4. When I am doing a Configuration Write Type 0 to write the End Point BAR0 with FFFF_FFFFh, the end point send an answer , when I follow this write with a Configuration Read type 0 to read the BAR 0 of the End point I do not receive any answer.
  1. Is there any configuration which avoid the read data to go through the F-Tile ?
  2. Is there any problem with my Configuration Read type 0 command
I have attached the STP file as well.
Thank you for help.
Serge
  • You may need to recheck your design if a given valid is not seen by the IP.
    Here is how a F-Tile RP reads another FPGA's VID.
  • Hi Serge,
    >>This doesn't look right. For a BAR test, I think you should use MWr and MRd.
    Rong
    • Serge93's avatar
      Serge93
      Hello Rong,
      Nice to see you again.
      BAR0 in address 10h, is in the Configuration Space not in the Memory Space, so you have to use a Configuration Access. I am using the same access with my Agilex7i-R-Tile board and it is working. So this is very strange it is not working on the Agilex-7F board.
      Thanks for help.
      Serge
    • RongY_altera's avatar
      RongY_altera
      Thanks for the clarification. I misunderstood your request in the previous message.
      From the stp, you were reading addr 0x01000010, not 0x10.
      Rong
      • Serge93's avatar
        Serge93
        Hello Rong,
        When using a Configuration Write or Read Request the address is compose of : Bus Number(7:) & Device Nb(7:0) & Ext_Reg(7:0) & reg Nb(7:0).
        So what you see is the Bus Number=01h and Reg Nb=10h.
        By the way, I have the same behaviour with the address=00h (Device ID & Vendor ID) in the Configuration Space.
        Thanks for help.
        Serge
  • The F-Tile is RP so it's type1. The CfgWr0 to EP BAR0 with FFFF_FFFFh is for finding the BAR0 size, right? Once the EP BAR0 is enabled, the RP can read/write to that BAR.
    Thus you need to set BDF on RP(type1), and enable BAR0 on EP(type0).
    Rong
    • Serge93's avatar
      Serge93
      Rong,
      Can you translate your last sentence in bus access to the RP IP in order I understand what you mean.
      Thank you.
      Serge
    • Serge93's avatar
      Serge93
      Rong,
      I recall you the bus access sequence I show you is working with R-Tile. This is exactly the same sequence.
      So why It is not working with F-Tile ?
      Thank you.
      Serge
        RongY_altera
        I think you should trigger tx_st_valid.
        Rong
