F-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
- 2 months ago
You may need to recheck your design if a given valid is not seen by the IP.
Here is how a F-Tile RP reads another FPGA's VID.
The F-Tile is RP so it's type1. The CfgWr0 to EP BAR0 with FFFF_FFFFh is for finding the BAR0 size, right? Once the EP BAR0 is enabled, the RP can read/write to that BAR.
Thus you need to set BDF on RP(type1), and enable BAR0 on EP(type0).
Rong
- Serge932 months ago
Rong,
Can you translate your last sentence in bus access to the RP IP in order I understand what you mean.
Thank you.
Serge
Rong,
I recall you the bus access sequence I show you is working with R-Tile. This is exactly the same sequence.
So why It is not working with F-Tile ?
Thank you.
Serge- RongY_altera2 months ago
Contributor
I think you should trigger tx_st_valid.
Rong
Hello Rong,
When I trig on tx_st_valid, it never trigs.
Do you have a PCIe specialist I can have access ?
Serge
