F-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
- 2 months ago
You may need to recheck your design if a given valid is not seen by the IP.
Here is how a F-Tile RP reads another FPGA's VID.
Hi Serge,
When I am doing a Configuration Write Type 0 to write the End Point BAR0 with FFFF_FFFFh
>>This doesn't look right. For a BAR test, I think you should use MWr and MRd.
Rong
- Serge933 months ago
Hello Rong,
Nice to see you again.
BAR0 in address 10h, is in the Configuration Space not in the Memory Space, so you have to use a Configuration Access. I am using the same access with my Agilex7i-R-Tile board and it is working. So this is very strange it is not working on the Agilex-7F board.
Thanks for help.
Serge - RongY_altera3 months ago
Contributor
Thanks for the clarification. I misunderstood your request in the previous message.
From the stp, you were reading addr 0x01000010, not 0x10.
Rong
Hello Rong,
When using a Configuration Write or Read Request the address is compose of : Bus Number(7:) & Device Nb(7:0) & Ext_Reg(7:0) & reg Nb(7:0).
So what you see is the Bus Number=01h and Reg Nb=10h.
By the way, I have the same behaviour with the address=00h (Device ID & Vendor ID) in the Configuration Space.
Thanks for help.
Serge
Hello Rong,
Any news, I am blocked now. Can you have the help from another person ?
Thank you.
Serge
