Serge93
3 months agoF-Tile PCIe Root Port 1x Gen3x4 - Configuration Read Type 0 receives no answer
Hello Support, I am using the Agilex 7F Dev Kit with F-Tile configured in Root Port Gen3x4. When I am doing a Configuration Write Type 0 to write the End Point BAR0 with FFFF_FFFFh, the end point se...
- 2 months ago
You may need to recheck your design if a given valid is not seen by the IP.
Here is how a F-Tile RP reads another FPGA's VID.
Serge93
2 months agoRong,
I recall you the bus access sequence I show you is working with R-Tile. This is exactly the same sequence.
So why It is not working with F-Tile ?
Thank you.
Serge
RongY_altera
Contributor
2 months agoI think you should trigger tx_st_valid.
Rong
- Serge932 months ago
Hello Rong,
When I trig on tx_st_valid, it never trigs.
Do you have a PCIe specialist I can have access ?
Serge
- RongY_altera2 months ago
Contributor
Thank you Rong.
Serge
