dc3
7 months agoCan't generate F-Tile Ethernet Hard IP Design Example
When I try to generate an example design for the F-Tile Ethernet Hard IP or even the F-Tile Low Latency 100G Ethernet IP, the generating step gets stuck in a loop and will stay that way until I manua...
paveetirrasrie_Altera
7 months agoHello,
May I know which Quartus version you're working with? Do the issue still persist?
Pavee
dc3
6 months agoI upgraded to 25.3.1 and now I get this error.
- paveetirrasrie_Altera6 months ago
Form the screenshot you've provided, the design has error. You won't be able to generate the design with error.
Please select the valid Device Initialization Clock and continue with generation.
Pavee
- dc36 months ago
There is no option to select any Device Initialization Clock. How do I find it?
You may select it from Target Development Kit Tab.
