shashwatss's avatar
shashwatss
2 months ago
Agilex-5 supported Transceivers
I am currently evaluating the capabilities of the Altera Dev Board DK-A5E065AB32AEA.
As most SFP+ and QSFP+ Transceivers are often vendor-locked, is there a list of qualified Transceivers available?
Intel E10GSFPSR and another Xcvr marketed as support for Nvidia did not work in my case, as I attempted to do the initial Testing using BTS App as per document D554638
Which transceivers were used by Intel(Altera) for qualifiying/testing the development board DK-A5E065AB32AEA ?
  • cblixt1's avatar
    cblixt1
    1 month ago
    It will not work that way. The test with external loopback assumes that you have attached a loopback plug to either QSFP0 or QSFP1, looping back TX to RX for each lane internally within the QSFP chosen. You have looped back QSFP0 to QSFP1. You have to get a loopback plug or you can only use internal loopback with this test.
  • umut_arrow's avatar
    umut_arrow
    I believe the SFP+/QSFP+ cages are not vendor-locked, but unfortunately I can't see a qualified transceiver modules.
    Looking at the Intel E10GSFPSR, it's a fixed 10G-only module. The 065A Premium devkit has an Agilex 5 E-series Group A device, and its ports are spec'd at 25G. This could be why this the module didn't work, as the SerDes isn't configured for 10G and it could be that the BTS image in'st falling back to 10G.
    Did you set the BTS PHY configuration explicitly to 10G? And what did BTS say exactly?
    • shashwatss's avatar
      shashwatss
      Thank you for your response. There is no option to modify the configuration in the BTS front-end.
      Having considered the 25G default setting, another attempt was made using the transceiver 25G which is marketed as compatible with Nvidia. The exact product is SFP-25GSR-85 (compatible with Nvidia Mellanox). This also did not work.
      Also, attempts with QSFP-SR4-100G(compatible with Nvidia Mellanox) along with the example sof config using BTS also did not succeed.
      • CheepinC_altera's avatar
        CheepinC_altera
        Just would like to follow up with you on this. Thank you.
    shashwatss
    sure. The issue was observed at the first start-up of the dev kit. The kit comes pre-programmed with an HPS Image, and this image was used for the initial testing as per the document D554638(published date 2026.06.19)
    I downloaded the development kit files as per point 2.3.2 of the document. Below mentioned is the case for QSFP28. Similar steps were also performed for SFP28. 10G SFP+ was attempted as well.
    • Path is \*\Altera_Devkit_design_package\DK-A5E065AB32AEA-26.1.0.104\examples\board_test_system\
    • start.batch was launched with admin rights
    • Clicking Agilex-5(as per Fig.8 in document) launches Figure 38.
    • Navigating to point 4.3.5.3 -> issue with QSFP28 design. Programmer crashes with message "failed"
    • The above screenshot is for *.sof* of DDR, but similar was for the case of QSP28 as well as SFP28 as well
    • Therefore, BTS GUI was closed. And Altera FPGA Programmer was used for loading the *bts_qsfpn.sof* file located at \\Altera_Devkit_design_package\DK-A5E065AB32AEA-26.1.0.104\examples\board_test_system\image\sm72si\PRD0\
    • Once the sof loads successfully, BTS GUI is launched again. Clicking on Aglilex-5, shows the current configuration of the board.
    • Attaching a 100G XCVR and cable for loopback - in the above case, we used the 100G Transceiver which is supposed to be compatible to Nvidia Mellanox. - Did not work. Tx at 100% and Rx at 0%.
    • Next, we used 40G QSFP+ Xcvrs which are "generic" - the exact meaning of such a transceiver is unknown-( dunno which vendor code was written in the EEPROM for i2C comm)
    • I repeated such a test-setup  for both the 25G and 10G transceivers, and tried using with BTS.
    • Sadly, I ordered all transceivers as Nvidia compatible and hence we it did not work as mentioned above.
    All transceivers were purchased from FS.COM. Exact product is SFP-25GSR-85,  QSFP-SR4-100G
    Hence, the query to inquire about the exact hardware components used by the board manufacturers to qualify the design on their end before shipment.
      CheepinC_altera
      Thank you for the update. To facilitate further debugging, I recommend using the XCVR Toolkit, or alternatively a simple XCVR design with SignalTap, to monitor the transceiver status. The XCVR Toolkit would be the quickest approach to get started.
      Please follow these steps:
      1. Generate an example design using the GTS PMA/FEC Direct PHY IP and target the relevant development kit.
      2. Select a simple configuration from the available example design options, preferably using a single channel and a lower data rate.
      3. Enable the XCVR Toolkit by following the instructions in the GTS Transceiver PHY User Guide, under the “GTS Transceiver Debugging Flow Walkthrough” section.
      4. Assign the transceiver pins to the SFP+ interface.
      5. Compile the design and program the resulting SOF file onto the development kit.
      6. In the XCVR Toolkit, enable internal serial loopback and monitor the TX and RX lock/status indicators.
      7. Run the PRBS test with internal serial loopback enabled. This will help verify the basic transceiver functionality without depending on signal integrity or an external loopback connection.
      8. Disable internal serial loopback, plug in the SFP+ module, and repeat the test.
      Please share the observations from both tests, including the TX/RX lock status, PRBS test results, and any reported errors.
      Please let me know if you have any questions.
      CheepinC_altera
      As it has been some time since my last response, this thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Altera experts.  Thank you.
    • cblixt1's avatar
      cblixt1
    • glenenglish's avatar
      glenenglish
      cblixt1 is also correct on their point.
      You will likely need to talk to the SFP module and configure it  (I2C etc)
