quartus ram gen full HDL
can Quartus ram generator, generated a full HDL code for simple dual port ram, so i can use for both non altera device?
- FvM
presume you are asking about synthesizable HDL code? Embedded RAM is a hardware feature of FPGA, HDL code provided by Quartus Megawizard or e.g. Xilinx RAM generator is only a wrapper. Respectively many parameters (memory organization, synchronous or asynchronous read/write, behaviour of additional signals) are target dependant, the code can't be easily ported to other devices.
Regards Frank
- KennyT_altera
Do you have further queries?
Agree on the above answer: Quartus RAM Generator mainly creates Intel/Altera-specific wrappers and may not be fully portable to other FPGA vendors.
For portability, write a simple dual-port RAM in standard synthesizable Verilog or VHDL. However, RAM inference and read-during-write behavior may differ between devices, so the design should be verified with each vendor’s synthesis tool.
- KennyT_altera
Do you have further queries? If no, we shall close the case.
- KennyT_altera
Closing the case since no further queries
