Agilex-5 supported Transceivers
- 1 month ago
It will not work that way. The test with external loopback assumes that you have attached a loopback plug to either QSFP0 or QSFP1, looping back TX to RX for each lane internally within the QSFP chosen. You have looped back QSFP0 to QSFP1. You have to get a loopback plug or you can only use internal loopback with this test.
sure. The issue was observed at the first start-up of the dev kit. The kit comes pre-programmed with an HPS Image, and this image was used for the initial testing as per the document D554638(published date 2026.06.19)
I downloaded the development kit files as per point 2.3.2 of the document. Below mentioned is the case for QSFP28. Similar steps were also performed for SFP28. 10G SFP+ was attempted as well.
- Path is \*\Altera_Devkit_design_package\DK-A5E065AB32AEA-26.1.0.104\examples\board_test_system\
- start.batch was launched with admin rights
- Clicking Agilex-5(as per Fig.8 in document) launches Figure 38.
- Navigating to point 4.3.5.3 -> issue with QSFP28 design. Programmer crashes with message "failed"
- The above screenshot is for *.sof* of DDR, but similar was for the case of QSP28 as well as SFP28 as well
- Therefore, BTS GUI was closed. And Altera FPGA Programmer was used for loading the *bts_qsfpn.sof* file located at \\Altera_Devkit_design_package\DK-A5E065AB32AEA-26.1.0.104\examples\board_test_system\image\sm72si\PRD0\
- Once the sof loads successfully, BTS GUI is launched again. Clicking on Aglilex-5, shows the current configuration of the board.
Attaching a 100G XCVR and cable for loopback - in the above case, we used the 100G Transceiver which is supposed to be compatible to Nvidia Mellanox. - Did not work. Tx at 100% and Rx at 0%.
- Next, we used 40G QSFP+ Xcvrs which are "generic" - the exact meaning of such a transceiver is unknown-( dunno which vendor code was written in the EEPROM for i2C comm)
- I repeated such a test-setup for both the 25G and 10G transceivers, and tried using with BTS.
- Sadly, I ordered all transceivers as Nvidia compatible and hence we it did not work as mentioned above.
All transceivers were purchased from FS.COM. Exact product is SFP-25GSR-85, QSFP-SR4-100G
Hence, the query to inquire about the exact hardware components used by the board manufacturers to qualify the design on their end before shipment.
