10 years ago
How to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one more layer above that which implements this controller as a 2-port RAM entity. It seems like overkill to use QSYS with NiosII though, plus I'm not very familiar with it. What's resource will help me implement this controller as a 2-port RAM entity in the simplest way possible?
entity sdr_sdram is
    generic(
        ASIZE     : integer := 23;
        DSIZE     : integer := 32;
        ROWSIZE   : integer := 12;
        COLSIZE   : integer := 9;
        BANKSIZE  : integer := 2;
        ROWSTART  : integer := 9;
        COLSTART  : integer := 0;
        BANKSTART : integer := 20
    port(
        CLK     : in    std_logic;      --System Clock
        RESET_N : in    std_logic;      --System Reset
        ADDR    : in    std_logic_vector(ASIZE - 1 downto 0); --Address for controller requests
        CMD     : in    std_logic_vector(2 downto 0); --Controller command
        CMDACK  : out   std_logic;      --Controller command acknowledgement
        DATAIN  : in    std_logic_vector(DSIZE - 1 downto 0); --Data input
        DATAOUT : out   std_logic_vector(DSIZE - 1 downto 0); --Data output
        DM      : in    std_logic_vector(DSIZE / 8 - 1 downto 0); --Data mask input
        SA      : out   std_logic_vector(11 downto 0); --SDRAM address output
        BA      : out   std_logic_vector(1 downto 0); --SDRAM bank address
        CS_N    : out   std_logic_vector(1 downto 0); --SDRAM Chip Selects
        CKE     : out   std_logic;      --SDRAM clock enable
        RAS_N   : out   std_logic;      --SDRAM Row address Strobe
        CAS_N   : out   std_logic;      --SDRAM Column address Strobe
        WE_N    : out   std_logic;      --SDRAM write enable
        DQ      : inout std_logic_vector(DSIZE - 1 downto 0); --SDRAM data bus
        DQM     : out   std_logic_vector(DSIZE / 8 - 1 downto 0) --SDRAM data mask lines
end sdr_sdram;
I need a wrapper so that this SDRAM controller is implemented like this:
Inst_frame_buffer : entity work.sdram_wrapper_frame_buffer PORT MAP(
            rdaddress => rdaddress, --    IN std_logic_vector(18 downto 0);
            rdclock   => clk_vga,       --    IN std_logic;
            q         => rddata,   --    OUT std_logic_vector(11 downto 0)
            wrclock   => camera_pclk,   --    IN std_logic;
            wraddress => wraddress, --    IN std_logic_vector(18 downto 0);
            data      => wrdata,        --    IN std_logic_vector(11 downto 0);
            wren      => wren           --    IN std_logic;
