11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- The SDRAM size is different for the DE0-nano vs my regular DE0 board. --- Quote End --- You can start Qsys and modify the SDRAM parameters. --- Quote Start --- Can I hire someone to make a quick VHDL wrapper for the Altera SDRAM controller I have as a 1-Port RAM entity that has multiple-master access functionality? --- Quote End --- Its not the SDRAM that provides the multiple master functionality, its the fabric created by Qsys. When you connect two masters to a slave, the fabric adds arbitration logic. --- Quote Start --- I don't mind doing it with Qsys either but I would need a tutorial that doesn't use a JTAG interface or NiosII. It seems odd that this is such a hard thing to find.. --- Quote End --- A Qsys system needs at least one master (otherwise there is no point in creating the system), and the two easiest ones to demonstrate in a tutorial are NIOS II or JTAG. What are you trying to do that is not supported by existing components. Perhaps if you could explain what you are trying to do, people on the forum can suggest options for you to look into. Cheers, Dave
