11 years agoHow to implement DE0 SDRAM as 2-port RAM
I currently use the tiny bit of memory on the FPGA for a computer vision project but it's way too limited. I have a stand-alone SDRAM controller from Altera (partially pasted below) but I need one mo...
11 years ago --- Quote Start --- What's resource will help me implement this controller as a 2-port RAM entity in the simplest way possible? --- Quote End --- The SDRAM interface has only one port, so you can only use it as 1-port RAM. What you are probably after is multiple-master access to the common resource. This is possible if the two devices (masters) access the SDRAM at a rate that is slower than the SDRAM interface maximum performance. Eg., two devices accessing 100MHz SDRAM at an effective data rate of say 10MHz would work fine. Multi-master arbitration of the SDRAM interface would be done automatically for you if you use Qsys. Here's an SDRAM example to get you started. http://www.alteraforum.com/forum/showthread.php?t=45927 This does not use NIOS II. It uses the JTAG interface to allow your PC to access the SDRAM. Cheers, Dave
