M_DK_FPGA's avatar
M_DK_FPGA
1 year ago
HDMI Intel FPGA IP as Receive with AXIS fails in Analysis & Synthesis of Quartus 24.3 Pro
Hi support,
When creating a design with "HDMI Intel FPGA IP" having significant values as:
- Direction: Receiver
- Enable Active Video Protocol: AXIS-VVP Full
- Support FRL: Untick (disabled)
Then Quartus 24.3 Pro Build 212 (newest) fails in Analysis & Synthesis with the errors:
Error(13224): Verilog HDL or VHDL error at hdmi_rx_core_altera_hdmi_1975_ozylggi.v(771): index 2 is out of range [1:0] for 'cv_vid_de'
Error: Failed to elaborate design:
Error: Flow failed: Errors generated during elaboration
Error: Quartus Prime Synthesis was unsuccessful. 3 errors, 0 warnings
Archived project is attached.
Question: Is there any known fix or workaround for this problem?
M_DK_FPGA
PS. It appears that an internal non-designer assigned value PIXELS_PER_CLOCK is assigned to 8, as for FRL enabled, thus causing an internal loop to go out of range.
  • Hi @M_DK_FPGA ,
    I understand your reason to turn off the "support Aux" and "deep colour" with reason to support your custom 24 bit pixel data.
    However , turning OFF support Aux and deep colour will make the output in-stable (blank most of the time).
    Also, This will only save minor logic utilization. That why we make those two as default to suit most of the use cases.
    Currently AXI Bridge is setting to 16BPS (16x3 48bits).
    If fewer bits are requires, you just need to pad the LSB without disable the AUX and Deep Colour.
    Detail about the implementation you may refer to
    Hope that able to help you to move a step forward, let me know if further clarification is needed.
    Wincent_Altera
