MichaelB's avatar
MichaelB
4 years ago
E-Tile frequency constraints
I've a question regarding the E-Tile transceiver and their constraints.
I would like to implement different data rates which I have already tested successfully using the reconfiguration interface.
Now I'd like to ask if it's necessary to create a constraint for the minimum and maximum frequency.
My intention would be to instantiate the E-Tiles with a lower data rate and create constraints for the minimum and maximum frequency used for RX/TX_out_clock.
I already tried it with the create_clock constraint to create it with their periods but obviously the values are truncated.
Can I specify ps or fs instead of ns for the clock period?
Another possibility would be:
Should I specify the highest data rate and the lower ones will be possible without timing violations, too?
Which 'strategy' would be the better one to avoid any issues with the E-Tiles during operation?
Michael
  • Hi,
    If you observe issue trying to constrain the output clock ie cannot find in tech map, would you mind to help opening a new Forum case and let me know the case. I will help to route to our timing team to better assistance. Thank you.
