E-Tile frequency constraints
- 5 years ago
If you observe issue trying to constrain the output clock ie cannot find in tech map, would you mind to help opening a new Forum case and let me know the case. I will help to route to our timing team to better assistance. Thank you.
As I understand it, constraining to the highest frequency does NOT guarantee that all lower data rate will work properly. It is recommended for you to use the previous clock group assignment to constrain for different frequencies.
alright I will create a constraint for highest and lowest frequency.
Is there any recommended constraint to use? Should I use create_clock on a specific port of the E-Tile native or can I use create_generated_clock?
I already tried it with the create_clock with the specific output clocks of the E-Tile native but this statement won't be recognised. The port name is not available in the technology map.
Could you help me which port I should constraint here?
Kind regards,
Michael
