MichaelB
5 years agoE-Tile frequency constraints
I've a question regarding the E-Tile transceiver and their constraints.
I would like to implement different data rates which I have already tested successfully using the reconfiguration int...
- 5 years ago
If you observe issue trying to constrain the output clock ie cannot find in tech map, would you mind to help opening a new Forum case and let me know the case. I will help to route to our timing team to better assistance. Thank you.
CheepinC_altera
5 years agoThanks for your help. I have routed the case to the timing expert and ping them through email as well.
