E-Tile frequency constraints
- 5 years ago
If you observe issue trying to constrain the output clock ie cannot find in tech map, would you mind to help opening a new Forum case and let me know the case. I will help to route to our timing team to better assistance. Thank you.
Please correct me if I am wrong, as I understand it, your specific inquiry is related to the tx/rx output clock constraint for different data rate. If yes, please allow me some time to consult our timing expert on this to if there is any guide or documentation on multi data rate constraint. For your information, I am more towards transceiver PHY and hardware instead of timing.
Just would like to check with which specific parallel output clock of Native PHY that you are trying constrain?
- MichaelB5 years ago
Hi CheePin,
thanks for your response!
Yes I'm referring to the parallel data clock (tx/rx out clk) of the Native PHY.
Michael
