MichaelB
5 years agoE-Tile frequency constraints
I've a question regarding the E-Tile transceiver and their constraints.
I would like to implement different data rates which I have already tested successfully using the reconfiguration int...
- 5 years ago
If you observe issue trying to constrain the output clock ie cannot find in tech map, would you mind to help opening a new Forum case and let me know the case. I will help to route to our timing team to better assistance. Thank you.
CheepinC_altera
5 years agoHi,
- MichaelB5 years ago
thanks for your help!
I have created a new thread for the E-Tile tx/rx out clock constraint here:
Michael
