E-Tile frequency constraints
- 5 years ago
If you observe issue trying to constrain the output clock ie cannot find in tech map, would you mind to help opening a new Forum case and let me know the case. I will help to route to our timing team to better assistance. Thank you.
Thanks for sharing your SDC constraint. It seems like you are target relatively high precision which I am not sure if TimeQuest will be able to recognize. I have had some discussion with Kenny, probably you can try to set something like "Create_clock 10ps... " to see if it works. Adding the "ps" suffix.
If it is not working, you might need to stick to the default "ns" time scale. Sorry for the inconvenience.
- MichaelB5 years ago
Hi CheePin,
alright I will do it another way. I will define the maximum data rate to get the highest frequency generated by Quartus in its E-Tile constraint files.
I can switch the data rate by PMA configuration which I've already tested & verified for my design.
Can I be sure that all lower data rates are working properly without defining a minimum frequency for the lowest data rate?
Michael
