delay in verilog
How can I insert one delay in a program but not in a simulation in verilog!?
I want to add a delay in my code.
like in modelsim simulation we write " always@ (clock) begin # 5 a <= b; end " this adds a 5 time units delay to the signal. can we have something in QUATRUS Prime for simulation becoz this is not working in QUATRUS. can someone help me out? - Altera_Forum
Thanks for your hint.
Anyway, I've tried but sop and eop signals seems to work fine. The valid signal, I don't know. I'll take a picture of the image on the monitor becouse is quite difficult to explain the effect I am seeing.. Now I'll try to delay ONLY active data/sop/eop signals ( according to the valid signal) ant to (re)generate a valid signal as output locked to the data/sop/eop. - Altera_Forum
Enclosing the chain of regxx <= regyy assignments in an always @(posedge clock) block would do the job.
thanks for your reply.
Well, I am trying to make a video elaboration system with to branches. One branch should perform a lowpass effect on the video (a 2d fir, or a 2d median qith custom logic, not altera's ones) and the other branch should propagate video packets without elaborations. The custom block has a latency of (~)12 clock cycles, and I need the two branches to be aligned. So, I was thinking to add a delay on the branch without elaboration, but it seems I am somhow wrong. I did other kind of delay bloks for my system without using fsm, but they do not work too good.. - Altera_Forum
You didn't tell what you want to achieve. I guess, the regxx <= reg yy chain is intended as a kind of delay. Unfortunately, it will work (at best) in simulation. In synthesized hardware, all regxx are assigned to the input value without any delay. This happens, because the assignment isn't made in an edge sensitive always block. Level sensitive conditions like @(fstate ..) are ingnored in synthesis.
ok, this is my code. Right now, it SEEMS to work. If anyone would take a look and send me feedback, I would appreciate a lot.
--- Quote Start --- module delay_finite_state ( clock, reset, ready, dout_ready, din_data,din_valid,din_sop,din_eop, dout_data,dout_valid,dout_sop,dout_eop ); input clock; input reset; input ready; input [15:0]din_data; input din_valid,din_sop,din_eop; output reg [15:0] dout_data; output reg dout_valid,dout_sop,dout_eop; output dout_ready; reg [1:0] fstate; reg [1:0] reg_fstate; reg [19:0] reg1,reg2,reg3,reg4,reg5,reg6,reg7,reg8,reg9,reg10, reg11,reg12,reg13,reg14,reg15; parameter idle=0,run=1; always @(posedge clock) begin fstate <= reg_fstate; end always @(fstate or reset or ready) begin if (reset) begin reg_fstate <= idle; end else begin case (fstate) idle: begin if (ready) reg_fstate <= run; // Inserting 'else' block to prevent latch inference else reg_fstate <= idle; end run: begin reg1<={din_data, din_valid, din_sop, din_eop}; reg2<=reg1; reg3<=reg2; reg4<=reg3; reg5<=reg4; reg6<=reg5; reg7<=reg6; reg8<=reg7; reg9<=reg8; reg10<=reg9; reg11<=reg10; reg12<=reg11; reg13<=reg12; reg14<=reg13; reg15<=reg14; {dout_data,dout_valid,dout_sop,dout_eop}<=reg15; if (~(ready)) reg_fstate <= idle; // Inserting 'else' block to prevent latch inference else reg_fstate <= run; end default: begin $display ("Reach undefined state"); end endcase end end assign dout_ready=ready; endmodule // SM1 --- Quote End --- - Altera_Forum
edit, still working about.
Right.
What do you really want? I mean why you want a delay in your design? I will answer you as much as I can. - Altera_Forum
Before we have to guess further about PLL usage, you should tell about the original problem as clear as possible.
Consider learning FPGA design step by step. You don't need to take all at once. - Altera_Forum
i don't know how use PLL!!:( but my fpga have pin with PLL!!!
